flipped over 2008 gtx 215
ritz
had a friend flip over my 2008 gtx 215 and couldn't get it back over for five minuts or so it was 1/3 full of water. pulled it out and drained it. do i try to start it or take it in?
pull the plugs, turn couple times, get water if any out, spray wd-40 in cylinders, if you can pull the oil stick, check to seeif water is in, oil will look mud/residue on stick, recheck the electrical boxes for water/moisture..
when i pulled it out i coulnt see any oil on dipstick, will the seats dry out ? they are water logged.
yah,...PM Seadoosnipe/Kustom Karl,..they have great info on procedure to replaced/add/check oil, in meantime, I'd pull plugs, spray some 40 in it, and try kick over, get if any, water out. possible,once you flipped it, right side up, water went thru intake/air...
