Been running hotter and hotter over the last 30 days. I could hear a fan run occasionally so I knew it was cooling. Decided to open it up to see if the vents were plugged. Nope, nothing that obvious.
Found I have three fans and only one would turn on every now and then. Put voltage to the other fans and they worked. So figured they were not being triggered to turn on.
Pulled the heat sink and found the heat sink grease that goes between the heat sink and the CPU was basically dust. Cleaned the dust away, put toothpaste on the contact points, put it all back together and now the fans are being triggered to turn on.
Ordered a tube of heat sink grease from eBay. Once it gets here I'll swap out the toothpaste.
It does smell minty fresh though.
