Ok hear I am writing this post for anyone with the same problem I had. 96 Challenger 800 single. Boat would run all day up to 5/8 throttle 5000-5500 rpm but if you opened it up 3/4 to full and got the revs up past 6000 after about 5-7 seconds engine would die as if you hit the stop button. Yes you could launch the boat full throttle then back down to cruise and all would be fine. So whats wrong fuel lines, clogged fuel filter, bad selector valve, improperly tuned carbs,
bad fuel pump, rave valves, Oil injection, ya and the list goes on. For me it was none of the above. Thing was just running out of gas plain and simple.
I'm new at this but after rebuilding the complete motor this year for a PTO failed piston, and rebuilding carbs and fuel pump, checking oil injection and fuel pressure plus an engine leak down test, all were good. So out we go and the same thing happen again, engine dies at 3/4 to full throttle. Ok rebuild the PTO only this time and Brand new carbs with fuel pump, test everything again and back out to have same problem. So you ask what the bleep is up with that.
Well hear is my answer. The manual says boat will use 12.2 gallons an hour at full throttle and thats fine on a stock motor or a .01 over one but I'm at .06 over now and also we do not have a pressurized fuel tank as do the seadoo's only an atmospheric vent on the fuel tank, that lack of pressure I believe starves the fuel pump of the little bit extra it needs to pump the 12.2 gallons an hour the motor needs since the pump on our carbs is rated at around 10 gallons an hour only.
So I bought a high volume fuel pump from mikuni rated at 16 gallons an hour and boat runs great full throttle no problem all day, did not make any carb adjustment when I put on the new fuel pump left as is to see how it ran and it was the best day of my summer.
Just think about what I said about the fuel delivery and it should make sense.
