Hello, 1997 seadoo GTX it ran and carbs were running out of fuel. Found the filters in the carb were plugged. Rebuild carbs, Then!! No Spark
It fired up ran then no spark. Replaced coil, ran ground from Ebox to battery ground. Then test light on the white wire and it shows a flashing green light, not a red as when testing 12v at the battery. I do have the 2 beeps when lanyard is attached. Clean all connections at the Ebox. Checked all fuses. One in the Ebox and 2 in the front box. I was thinking about checking the mag pickup but did not want to do that if the white wire was showing a pulse. Can anyone assist me further please. I do own a multimeter from Walmart and have no idea how to use it.. thank you for your response, All ideas are appreciated.
