First post-need help ?
Offtrail
Hey guys, new to the forum (first post !) and I hope someone can help me out....my wife picked up some rocks last year in her GTI 130 so we had the wear ring replaced . It works and sounds good at idle, however under throttle, there is a small vibration and the top speed is not near what it used to be ? Any ideas what I should look at next ? Thanks in advance.....
It looks fine but I'm thinking it may be off balance.....do you think that would be the problem ? It'll be coming out of storage soon so I guess I should order a new one....
Confirm wear ring is good. If you can't see any damage to the impeller the shaft may be bent. Can you safely get to the shaft? If so, hold a crayon near the shaft and slowly move it closer and closer. If it touches only in one area, the shaft is bent.
