michaelbt2
I just bought a 2005 Sea Doo Challenger 180 from a dealer. It had 16 hours on the boat as it was stored in a boat warehouse prior. All mechanicals and other tests were good, running as it should.
Took it out for the first time last weekend. Appeared to drain gas VERY quickly. Had a full tank. A mile down the lake it was at 3/4.
Took it out today (following weekend). It was at roughly 1/2. Guessing it was the way it was sitting in the water showing different readings. There are no gas leaks. Not in the 3 weeks I've had it have I smelled any sort of leak. Still appears to be running gas VERY quickly.
I've run the boat maybe 30 minutes and I've used over half a tank.
It's running at 6000-8000 rpm at 1/4 throttle.
Question: As mentioned it's my first boat so it has to be me in some way. Do you think I'm not getting up on plane so the back is dragging? Is running at 1/4 throttle bad? Just confused as to why it would drain gas like it does?
