I have a leak somewhere. I have fixed the freeze plugs and verified that they are not leaking. Doesn't appear to be coming from the exhaust anywhere.
I took the seat off and put the nose into a fixed dock and ran it for a while looking inside the hull and cannot see anything obvious. The bilge pumps appear to be working, but not as good at they should.
I drove it without a seat for 10 minutes, and again, cannot see anything obvious.
BUT!!! I turned the engine off and put all my weight on the right side almost sinking the ski. Nothing. But when I put all my weight on the left side, I can clearly hear water bubbling in
Let it "fill up" which is about 1-2 gallons of water, and put it on the trailer and drove it home. Still had the 2 gallons water in it, and did not appear to be leaking from the hull...
Where should I start looking from here?
It is NOT the carbon ring, exhaust, does not appear to be coming from the rear, and sounds like it is coming from under the engine, maybe under the exhaust pipe. I am pretty sure (but not defintely sure) that it is not the coupler on the exhaust pipe. I could clearly see it from the front when i was running the ski against the dock.
