Book said to get idle screw to touch, then two full turns, and line up the marks on the oil injector.
Primed it and all is running fine, but I am not clear on where the allignment marks on the injector are supposed to be in the end.
Are they alligned correctly now, or does it have to line up at IDLE?
2 turns in was quite a bit higher than idle when it started up. Closer to 4000 rpms.
