filling up with oil
seedoogsxr
i just bought a see doo challanger 1800 its a 2008, i got it cheep because one of the engines keeps filling up with oil and then it hydro locks, i pull the plugs spin it over blow out the oil it will smoke for awhile but run fine all day, then let it sit overnight and the cylinder is filled up again, i guess its a problem with the self oiler??? anyone had this problem please let me kno thanks.
2008?
If it's a 2008, I'd take it back to the dealer. It isn't even a year old yet.
If it's a 2008, then it's a 4-TEC, which shouldn't hydro-lock from oil. It has an oil sump and oil pump. The oil is suppied under pressure to the valve train then to the crank. The only way you could get oil into the cylinder is from a leak of some sort, between the rings.....:cheers:
