File or replace impeller? Pics attached
Can I file this down with a file/dremel or should I look into a couple of those solas 16/23 impellers or I’ve seen that SBT does OEM remans for about $100?
Thanks
Donnie D5119F4B-37AA-4A2A-A182-68C90C95DD60.jpeg42A8AD7D-AFB2-470F-B90A-176DF705B8FF.jpegE5E90D6C-91DA-44C6-9C5D-4623F95D8502.jpeg
That's not bad at all. Just clean it up and you are good. The leading edge should be sharp-ish... but you dont' have to remove the divots. So, don't try to grind it back to s "Clean" edge.
What about this side? Thanks so much. Also for some reason that boot tore when I yanked the pump off the back of the hull..
737C831E-CE2E-4FD8-860F-2FCB32556815.jpeg162BE92D-1DA0-486C-9124-C84FB8097A1A.jpeg3F14F798-E2F8-4B82-9E31-C634DD338A8D.jpeg
That one is in pretty bad shape. If it were mine I would send it to Skat Trak for a refurbishment.
