Fault Code p0113?
dmt2661
So I just bought a 2010 GTX 155, took it out on the water and in the first 2 minutes a check engine light came on. The fault code read P0113. The seadoo fault codes says this is a "Intake manifold shorted to 12V or open circuit". What is this? Can I fix it myself? Anyone else have this issue in the past?
Intake manifold air temp sensor problem. The sensor is at the front right lower of the intake manifold. Simple to replace but these are very reliable so quite possible it is a wiring or connector problem.
Found the issue the. The metal clip is missing on the plug that attaches to the sensor. 2 zip ties and I was back in business.
