robman66
Took the boat out on the water for the first time today. Started right up, no problem. Idled around 1100-1300rpm, sounded great. After cruising for a minute, and then putting the throttle handle in idle position, the motor stayed around 3000rpm. I bumped the throttle up a bit, and then brought it back down, and it was idling around 2800rpm.
Bringing it into the marina was tricking due to the high idle. I would have to go from neutral to reverse just to slow it down in the channel. But every time I switch it from N to R it would bump the rpms up to about 4000, and then it would drop to about 3000. It made docking it quite scary.
What could be causing the high idle?
Hoping to go out again tomorrow, but only if I can find a solution to this first. Thanks.
