Thanks for starting a thread like this.
I was planning to get depth finders on a new Wake model to help know if the water is shallow or not when wakeskating as another safety check. I am getting back into wakeskating. I used to spec out the location by eye but it would be a nice feature to cruise around at a speed that the depth gauge is accurate to get some real world readings in addition to using eye sight. I can't seem to find any information about how accurate the depth finders actually are. Do you guys know how accurate they are or maybe someone else reading this?
The water I will be in will likely be not much more than 10 feet most of the time and probably more like 6 most of the time. Are these depth finders meant for shallow water readings?
1. If the water is 4 feet deep, how far off would the readings be? What would the variation be on that? Would it show 3 to 5 feet or is it more accurate than that or worse than that maybe showing 8 feet when it is 4 feet.
2. What speed do you have to slow down to for it to be consistently accurate? 5 mph, 20 mph, etc? We can slow down to spec out the area first so slower speed would be ok for us.
3. What is the minimum depth reading? Can it detect and report 2 or 3 feet?
