Lemon?
:cheers:
Looking into the extended warranty on my 08' Challenger. What should I be looking to pay for a 3 year extension? Anyone mind sharing what they paid would be awesome.
What I have always looked into in extending a warranty is the fact, what problems have I had thus far and would spending this money, be justified.
If you buy a lemon, then yes, extending the warranty is a good idea. But, anything you have had covered or repaired since you bought the first warranty, is still actually covered even after this one runs out.
For instance, if you had problems with the slip washers that you used the warranty several times, then it expired. One month later, the propblem happened again, by law, they have to once again, repair that problem because it'll fall into a category that is like a lemon problem.
I've also said, if you buy something and for the first 2 years, you've had no problems and it's ran good, why spend the extra money that you may never use. If you buy a motor or something along those lines, if it lasts under hard riding for a season or two, that means you've bought something that was built with integrity and will probably last forever.
My dad still has his 1962 Chevy that has over 300,000 thousand miles on it and has never done anything but change the oil and do the simple maintenance. So, he got a good motor......... I hope that helps you understand when it's time to extend, and time to realize you got a good, dependable motor.....
