prairieboy
Recently did a top end rebuild on my 787 Speedster motor. They bored the cylinders 0.5mm over.
Took her out on the water and was doing proper break in procedures but I noticed the engine would surge around the 5 to 5500 rpm mark. I'd back off and it would be "ok". But just doing some quick testing I took it up past 5500 rpm and the surging seemed to stop. I didn't want to push too hard.
I talked to a couple of places and one theory is that my raves are not functioning properly. The idea that the over bore and the springs getting weak and so on sounds plausible especially at the 5000 rpm mark as if I recall correctly that's when the raves start to operate.
So a couple of questions. Does this seem to be a logical place to start? I mean, if I were to buy a rebuild kit, would I also need the guilotine. The old ones were in good shape and shaved down for the over bore. One place I checked said that new guilotines would need to be shaved down, but a seadoo mechanic said that not on a 0.5 mm bore that there is still plenty of clearance with new ones.
Another possible cause could be an air leak and the mechanic said to check the water strainer, but I can't seem to find reference to one in the shop manual. Said the o-rings on the strainer get old and start to suck air.
So many questions and chasing a few ghosts, but I thought I'd ask the experienced folks on here!
