Exhaust rubber hose
franktx
I have a 1997 Challenger 1800 the rubber exhaust hose that leads to Hull is busted and pouring in water. lol
Anyone else that has had this issue ,where is best place for me to find a replacement for this hose Hi temp ?
which one is it? the elbow on the Port side or the formed hose on the Starboard side? or is it the plastic exhaust thru hull itself?
I`m pretty sure they are obsolete parts and you`ll need to improvise from automotive hose, or silicone elbows and couplers...
post a few pics...
It's the formed hose on the starboard side that leads to the hull fitting
I will get it off this weekend take pics check length
and ID .
I will try and search for some hi temp corrugated hose .
and ID .
so it`s the "s" bendy looking hose? see if one from a 98 challenger 1800 is the same part number? I`ll look to see if I still have the one I took off... lemme know...
97 RH >
Exhaust Hose R. H
204340028
98 RH>
Exhaust Hose R. H
204340028
according to this> http://www.sea-doopart.com/oemparts/a/sea/500cf878f870021b3c6a7f0a/engine-support-and-muffler
and this>
http://www.sea-doopart.com/oemparts/a/sea/500cfa7ff870021b3c6a7f85/engine-support-and-muffler
it`s the same part...
Yes I'm pretty sure I read that part number fits 97-02
Yes the bendy one on driver side engine
Let me know if u find one
I`ll dig thru my stash over the weekend (Sat). I recently moved, so "if" I have it it is in a box somewhere...
I had a quick second to go look on the shelf and luckily found the box marked Challenger mufflers, the hose was still in the box and appears to be ok. mind you tho it is original...
Pale Rider ,
I sent you a PM although it doesn't show in my sent items makes me wonder if it went thru let me know if you received it
Frank
