I had an oil leak last year and had to remove the exhaust manifold to get to the oil intake WAY WAY below it. It was just a clamp that needed tightening and I solve that issue
I then proceeded to reconnect the exhaust manifold and used a thread blocker to secure the 8 bolts. Well my son drove it for a while and then everything came apart. The 8 bolts came loose. Come the find out the thread blocker that came from my neighbor was purchased at HARBOR FREIGHT. So it was probably not the right kind to use
Here we are a few months later and the sea doo it still not put back together and here is the rub.
WHEN I LOOK AT THE PART DIAGRAM for the 1998 sea doo GTI there is a small drop that indicates to use molykote NOT LOCTITE 242
WHEN I LOOK AT THE PART DIAGRAM FOR A 1998 SEADOO GTX the diagram indicates to use LOCTTITE 242
Does that make any sense? I have the 1998 GTI. would it not make sense to use loctire there? Is molykote a thread blocker also?
I want to do this right and want to make sure this thing does not come apart anymore.
ALSO is it necessary to put lubrication on the manifold gaskets?
I appreciate all the help. New to this repair thing. Answer like I'm a 2 year old. all the details possible.
thank you
thank you
