95sportster
I've already solved this issue but thought it may be helpful to anyone with the same problem.
I was cruising out on the river a few weeks ago (testing out the MPEM I repaired) and about 15 minutes into the trip the engine gets loud all of a sudden. I pop the hood to see whats going on and water is leaking everywhere from the exhaust manifold. All 6 manifold bolts had vibrated loose in the 16 hours that I've put on this motor. The vibrations had also ruined the gasket so even when I tightened it back up the leak still persisted.
I traced the problem to the rubber bushings that hold the exhaust cone to the manifold. They were distorted and probably allowed it to vibrate more than normal. I've replaced the gaskets and torqued the bolts to the correct specs and am waiting on the bushings in the mail. I should be back on the water in the next few days but just thought I'd share for anyone with similar issues and to remind people to check those bolts occasionally.
