ghostboner
Manual shows two bolts get loctite 515....cuz of water passages I read elswhere....Manual doesn't state that info...so I inspected each bolt hole and found the upper left does have a water passage...however the diagram shows the two inner bolts the one on right gets loctite 515...however that bolt hole doesn't have a water passage...is the diagram wrong? There is one other bolt hole with water passage but that bolt hole gets covered wth gasket and flange of exhaust manifold....I'm curious!!!
