98 sportster single rotax
I just finished replacing my wear ring and I figured I would crank the boat up. I haven't cranked it since last summer. I charged a battery last night and went out to crank the boat today. All I get is a click. I've checked fuses etc. The solenoid is working because you can hear the starter try to turn the motor. It makes a loud single click. After trying to start the engine for a minute or two, the ground wire gets extremely hot. I pulled the plugs and I could see one of the pistons towards the top of the head. After trying to turn the motor again, I could tell the piston went lower. So, I know the starter is doing some work. I'm wondering if I had some water in the engine that's caused it to seize like this. Any suggestions on what I can do? I've read there are some drain plugs on the bottom of the engine. Would it help to remove them to relieve pressure? I am at a loss here.
When I replaced my wear ring, I put the impeller on pretty tight. It would not move inside the housing with a free hand. I did go back and loosen it just a hair so you could turn the end so the splines would line up.
