what's up guys. i'm havin a bit of an issue with my 94 xp. it has the 657 in it. i've done all the usual post searching and think i MIGHT know what the problem is but here goes... a few weeks back, my brother was on it, hit a wave, came down, and it's been running rough ever since. if you are at an idle or gently hitting the throttle, everything seems fine. but once you hammer down, the engine vibrates ALOT and it would die if i would keep the throttle pushed. i'm a pretty versed auto mechanic so my first thought was a spun bearing or harmonic balancer or bent shaft but after some searching on the forum, i've found the most common answer is debris in the impeller/pump. does this sound right? i already looked up in there and didn't see anything. could i have missed it?
tim
tim
