Any help would be appreciated
Background:
At the end of last season boat suddenly lost power, but would start.
Pulling the head I found a hole burnt in PTO piston so boat was put away for the winter.
After pulling off the cylinders, now I have found the PTO side of the case has a good cupful of water/oil/gas inside but the mag piston and crank case look normal, with just a bit of oil at the bottom.
The lower end of the PTO side has very light rust on the counterweight but crank end rollers what I can see of them look fine. You can actually see the waterline on the counterweights in the pics.
Questions:
Am wondering how water got into only one side of the crankcase. Crack in casing to water jaket , failed gasket?
I am assuming that water in the crank = contaminated fuel mixture = lean condition = burnt piston. Make sense?
What is my next step?
The first pic shows condition of the Mag side case , second id the PTO (failed ) side
Thanks
Background:
Questions:
Thanks
