Ton's of great info on here guys, thanks. I have just purchased two jet ski's, a 97 gtx and a 97 xp. After reading this forum I have already removed my carbeurators and cleaned them and replaced my fuel line and cleaned the fuel system components. I have also learned how to adjust the cable from the carb to the oil pump, the guy that had these before me had no mechanical ability whatsoever. I have done a lot of searching, but have a couple of simple questions.
(1) what size engines are in my ski's? The guy before me didn't know and I'm not sue how to tell, I don't see it marked anywhere on the engine. I need to know so I know how to set the high and low speed fuel mixtures.
(2) I have read that the RAVE valves either need to be threaded all the way in or flush with the black plastic for better take off or for long periods of WOT. Which setting is for which performance?
Thanks a ton guys!
BTW. inside of my fuel lines and filters were horrible, I have no idea how these things even ran! Everything was full of a green gel-like gunk that sticks like glue, can't wait to run them again, should have a lot more power!
Thanks a ton guys!
