Engine shaking and water coming in
sea doo doo
Have 97 challenger twin rotax engines. engine on passenger side started shaking somewhat and water is pouring in under cover that protects drive shaft to pump. took cover off and noticed water coming out by rubber boot close to engine. What to do next? Also, boat wont get on plane with one engine????
This is your second thread on same problem. I posted an answer in the first one.
If you need to find it then click on your name and find latest threads.
You more than likely have a broken motor mount or nut came off for hte engine moving. Check the carbon seal boot & drveshaft to make sure your didn't damage the boat in that area and you need to put in a repair sleeve. If the engine moves to much to take on water since the seal work put applying pressure.
