HIN and the EIN....
You have two numbers for your boats identity.
The HIN (hull identification number) is located on the lower right hand side of your jet pump.
The EIN (engine identification number) is located on the engine. Open the engine cover and looking from the top, you should see it stamped on the back of the casing, just over the PTO flywheel on the right, or it will be all the way forward, looking from the top, stamped on the casing next to the magneto.
Good luck.........let me know if you need more help.:cheers:
