Hi,
I am currently trying to repair my 657X engines after finding some major corrosion issues in one of them, I have spent a few hours cleaning the jugs up the best I can which has taken me from this
to this,
Although it is not perfect i'm guessing it should function well enough, however my issues / questions are as follows,
First of all as can be seen in the images a lot of the inner edge is missing which holds the seal in place, now I am in 2 minds what to do with it, I am considering using some worth bond and seal to bond the seal into place against the outer edge and then use some more sealer on top. The other is not to bother with the seals and just use a qood quality sealer around the outer edges of the jugs.
Does anyone know how much pressure is placed in the jugs as I know a lot of the water is passed through the exhaust from the pump so i'm guessing the pressure is fairly low and does anyone see any reason why my ideas wont work, I am guessing as long as I keep the water from leaking out of the jugs when running it should be no problem?
The other question I have relates to the drains / fill holes at the bottom of the jugs, I only seem to have holes for the drain on the exhaust side of the jug (2 in each jug) but on the other side there are no holes although thee are some fairly deep holes that are full of crap which I have done my best to clean out but have been unable to fully clean out.
Here are images of the holes I do have and the ones on the opposite side.
Any advise appreciated.
Many thanks
Andy
to this,
Many thanks
Andy
