Hey so here's some background on the situation, I'm a licensed mechanic and I do some small engine work lawnmowers and snowblowers
I have a friend of mines 02 challenger 1800 which he didn't winterize (left the plug in) and when I got it, the engines were literally submerged in water possibly all winter long. They are both fresh rebuilds last year, and he said he has always had problems with one of them. I was able to get them started up and one of them to idle and run normally, the "good" one. The other one I could only keep running with a minimum of 50% throttle and only while playing with it at the engine, by hand. Both engines sounded like they had a loud "tick" or knock at first. I've seen heard the noise before on a dirtbike I serviced, cleaned the carb, new gas, new plug and no more "tick".
One of the engines the tick went away after running it for a bit after it was all cleaned up.
The other engine doesn't start at all now, not getting any fuel when I pump the carbs by hand. I've removed the carbs, haven't totally opened them up yet. Both engines new plugs and I didn't replace the gas (it smelled good, but I did top it up with new gas)
Has anyone heard of this or have any advice where to start?
I felt like the "bad one" had a lot of resistance while running which is why it needed 50% throttle or more to keep it running, but it cranks over exactly the same as the good one. (Could just be the carbs weren't pumping much fuel? So it was getting too much air not enough fuel)
