stevendandalides
2006 Wake---in the process of changing the oil today I managed to break off a short (1 inch) piece of the plastic tubing for the fluid extractor--only to have it fall down into the oil dip stick tube. It was too far down to retrieve. I was able to use the remaining plastic tube to drain the oil via the dipstick tube--the broken-off piece apparently fell down all the way into the oil pan (reservoir)??
Any suggestions on what I need to do to get the plastic piece out of the ?? oil
reservoir (pan)? Is it likely to cause problems if I am unable to retrieve it?
Has anyone had a similar experience?
Any help would be most appreciated.
