Engine oil capacity
Anyone know how much engine oil a 01 utopia 185 with a 200 optimax hold? And what a continuous beep means? When back off throttle goes beep pause beep pause beep and when back off throttle stops?
Yes how much 2-stroke oil does it hold I meant
Not 100% sure but-
The 240 EFI uses a separate tank that holds about 3.5 gal. + the engine mounted tank that holds about 1 quart.
You will need to google beep codes or look them up in the service book.
