Engine hours on '09 230 Wake?
salamander84
Bought an '09 230 Wake but can't find an hour gauge. Is it buried in Perfect Pass somewhere? I feel like an idiot even asking but can't find any info in the manual and a search of the Forum came up empty.. :confused:
Thanks for any help!
The only place the seadoo would have a hour guage is in the module that the seadoo dealer can only access it. I installed one in my 200 speedster in the front compartment under my ice chest. Works perfect. Connect it to a purple + wire so it only registers when the Dess lanyard is attached.
Karl
Thanks Karl..
Much appreciated..
Karl
The hour meter can be found in the perfect pass.
If you have the manual of the pass system it will tell you how. If not I can look in mine for you. But I know it is there for sure
Hi,
Thanks for the reply! Unfortunately I've misplaced my Perfect Pass manual and haven't been able to locate one online. If you could take a look at where it's hidden it would be greatly appreciated!
Do you think the perfect pass on 08 is the same on an 09? I can't seem to find the hour meter in the perfect pass, manual doesn't have anything for it either.
Sorry for the slow response and I haven't had time to look through my manual. But if I remember correctly with perfect pass on, if you hold both the menu and up arrow together it should bring up more options.
One being system info. It should be in there.
As for it being the same as an 08, I don't think they changed perfect pass in 09, so I would think it is the same.
