Just redid the top end of one of my engines this spring and got about 6 or 7 long doays out of it with no problems. The last time out I i went for a good 6 mile ride over to a local bar and back. got all the way back to the channel and i was slowing down when the engine made a mellow clunk clunk. Ok i thought it was the starter but i just removed it and it works fine. i took the head off and there were pieces of the rave valve sitting on top of the piston... the pistons move freely with no damage or marks at all on the top of the pistons but when i go to turn it over it gets stuck at certain points, i can get it to move past that point by working it back and forth but it will get stuck again. sound like its time to take the whole engine out? in the hole where the starter went there was some metal shavings but all the teeth are in tact. do you think a bearing went? a rod?
