robomatic12
I can hear a knocking noise internally and the engine won't start so I pulled off the cylinder head and I found damage from metal going through the forward cylinder. I'm not sure what this was caused by, if it is detonation damage or something inside that let loose. The bore isn't very scratched up. I pulled the rave valve on that cylinder to see if it came apart but it looked normal. Also that piston doesn't come up as far as it should, leading me to believe the rod is bent. In the photo that is as high as the piston comes up. I've been using seadoo xps 2 synthetic oil.
Little piece of something embedded in the cylinder head
Other cylinder
Other cylinder
