engine cooling fitting leaking
sptfr43
is the engine cooling fitting that goes through the back of the boat replacable on a 95 speedster? Mine seems to have a crack down the side and the eng comp fills with about 8" of water overnight. oops, turns out is the water inlet from the jet pump to the tuned pipe. guess that means the pump has to come off huh?
