I have a 96 XP and a 97 Challenger, and one is one way, the other is the other way.
The XP has the shims between the floor and the mount, and the Challenger has the shims between the mount and the engine block (my preference). That way I can pull the motor mounts and block all at once and the shims stay put. The XP was a little more of a hassle because the shims slide around while you are trying to get the bolts into the mounts.
I also did the "align by sight/then bump over to straighten" method, but I was able to keep my original shims in their original locations, because they were between the hull and mount, and I pulled the motor off the mounts, leaving the mounts in the hull.
