SeptemberC
This summer after getting my Islandia out of storage we had an INTERMITTENT issue that was a long alarm along with a momentary cut in power (limp mode). This occurred the first several times while running on plane close to WOT. This alarm and limp mode had happened years before when I found a fender had fallen down and was laying on my pee hole hose. Assuming this had caused some kind of overheat alarm.
Then one day we towed the boat 1.5 hours to a lake and it idled with no problem. When we reached the end of the No wake zone, as soon as it was given ANY throttle the alarm went off and limp mode triggered. (See ground wire issue below?)
We had no access to a scanner to read fault codes so I chose to replace both port and starboard head temp sensors, water pressure sensor, new spark plugs. THE LARGE THICK GROUND WIRE that is secured to the coil pack frame was rotted, crumbling and falling apart. I purchased a new one but my husband took one of the bolts loose that holds the ground strap on to the frame out but the other bolt is between the engine and the coil frame and difficult to get to. . He and my son in law determined it wasn’t important . We took it to the water and this is a video (sound only) https://m.facebook.com/story.php?st...UYnV7d4Cx4TcfDVKunnxW8uLzRgT3fzl&id=605164516 of the IMMEDIATE SICK SOUNDING alarm that goes off along with a SICK engine trying to run. AND HUGE ARC can be seen in the area of the coils!
(It was dark outside)
We took my Islandia to a marine shop yesterday (PTL that I found someone who was willing to work on it here in WV) The first thing he did was put the ground strap back on. Later in the day he said that he had tried to start it and unfortunately it’s running the same.
I would greatly appreciate any thoughts, suggestions or recommendations. It is a 2003 so I have electric oil pump. Someone prior had suggested that the plastic gear oil pump had failed which mine does not have.
serial number is 0E415631
