pwgsx
As I was going thru the boat this weekend looking for any issues, I found the multi pin connector that is going into the fuse box interface corroded. The green seal on the plug was half missing and it was a little wet inside ( probably from the bath I just gave the engine bay). I cleaned off the pins the best I could and dried it out. How can I seal this so it wont let any water in ? Is there a special kind of grease I can use? It seems the other plugs have this clear grease on but I don't know what it is.
Next I found 1 of the 2 blowers not to be blowing. Are they fused independently? I always thought the blowers blew air into the engine bay but the one that works is sucking air out- guess you learn something new every day.
Lastly, I have one DESS key that's black that starts both engines and one that's yellow that only starts one engine and gives a solid beep when I put it on the DESS post. Not sure what is the deal with that but I think that one is a dealer fix with the BUDS system.
