Periodically I have both engines on the speedster randomly die always at the same time. There is no rhyme or reason when they do, sometimes crawling out of the channel and others after I have been running at 45 MPH. Only thing I have to do to start back up is shift to neutral and I am good to go again. Only other thing that happens when the engines cut is that all gauges lock up where they are running (RPM & Speedo).
I am guessing the problem is electrical somewhere as often the boat will run like a top and others it will stall out multiple times but the only common factor is that it is always both engines that cut out at the same time.
Any ideas as to where to start looking to correct the issue?
Thanks,
Thanks,
