The information center on my GTX 2002 Di gives low fuel although I added gas it shows:
1. fuel level display shows no reading --- all the time
2. warning light and fuel low sign are on and off- when i remove lanyard and re-connect it ... sometimes no warning light or fuel low sign appears but fuel level display shows nothing
3. Buzzer code is off
Unfortunately, in GTX Di model the fuel sensor is integrated with fuel pump ... is it possible to replace it without the pump? is it an easy procedure? Is there any fues to check?
What if i ignored the low sign and used the ski with "fuel low" light on ... what happens if for example engine overheat.. will the information center show engine over heat or overheating will be masked with fuel low sign
