Ebay rebuilt 717 engine vs new sbt 717 vs bottom end rebuild | ENGINE FLOODING WITH OIL
nbaddorf
Hi, I have a 1996 Seadoo GTI, with a big problem of leaking oil into the cylinders. I have thoroughly gone through the carburetors, and know they aren't leaking fuel. Even with the fuel selector switch turned off, both cylinders fill with a puddle of oil within 1 minuet or running. I have removed the oil injection, and therefor have deduced, along with other members on this forum, that I have a leak in the bottom end of my engine.
(More in-depth backstory) - I have read many forums about similar issues like this. They all refer to having a geyser of oil fly out of the ski when the plugs are pulled. I have never had lots of oil come out. Many people also have hydro locking issues due to the oil. I have never had an issue with that. The other people I have read about seem to have this issue only initially, then the ski burns all that oil up, and it runs great again. As for my ski, I get a puddle of oil in each cylinder after 30 seconds of running, causing it to die. I have never herd of people having a leak as bad as this. Am I missing something?
So, I am wondering what your experience/recommendation is of 1. buying a refurbished engine off Ebay. 2. Buying a new engine on SBT. 3. Trying to rebuild bottom end of my engine myself.
With options 1 and 2, I am wondering what there quality is, and if I will likely have problems with the engine. As for option 3, I am a 16 year old guy who is willing to learn, but has limited funds, tools, and knowledge. My worry with option 3 is that I will incorrectly rebuild the bottom end, and spend as much money as it would take to buy a new engine.
Thanks for your help, I have been working on this thing for almost a year and really hoping to get to use this this year.
It is very strange that it only happens when running as typically crank and rotary seals cause the most leaking when sitting.
I think to rule out the oil pump I would disconnect it and try premix for a 1/2 tank and see if it is still getting too much oil when running.
Have y'all ever used seal rejuvenator? Do you know if that is bad for the engine or would that maybe help my problem?
Ok, thanks. Quick question, I am in the process of pulling my engine apart, and I am trying to take off the PTO flywheel. I found the special bolt things that fit into the pto to help take it off. Do you recommend those? Also, in the seadoomanual, I was reading something about having to time the PTO flywheel. If you don't mind, could you explain how to do that? I was confused by the manuals instruction. Thanks so much!
If your talking about the rear flywheel (PTO) I prefer a chain wrench and locking the rear piston with a block of wood.
No, no timing on the PTO, it just threads on.
Ok, so I just was looking at my engine (which is currently all taken apart), and I noticed that the rotary valve has scoring and a divot cut by something that must have gotten in the bottom end of my engine. I also noticed that, when turning the crankshaft by hand, the RV doesn't move at all. Just checking here, but the RV is supposed to move, correct? if so I guess I have something majorly wrong in the bottom end.
Yes, something locked up the rotary valve then stripped the brass gear on the rotary shaft that is turned by the crankshaft.
You will have to pull the entire engine apart.
Well, the only good news there, is that the engine is all apart already, because I was planning on training it in with SBT for a new engine. Is the brass gear an easy fix, or will it be hard/costly?
You have to split the cases and inspect the crank and rotary shaft for damage. Sometimes when the brass gear strips it bends the shaft and dislocates the crank gear.
I'm curious to hear what you find with the crank, rotary shaft, and RV seal, especially if/when you split the case. The rotary shaft damage must have damaged either the RV seal, or both crank seals for you to have oil in both cylinders.
FWIW, I have a 98 RFI that has a badly leaking inner crank seal (MAG side) with all the symptoms you mentioned in your original post. It fouls the spark plug, causing a rough idle and eventually stalls. But it is definitely only the 1 cylinder. You have a bigger problem with the rotary shaft.
So would y'all recommend that I open the bottom end or just replace the engine? I am trying to mix saving money with hopefully having the ski working in the next 3 months.
Rarely an easy decision. As a gearhead, I usually lean towards self-performing so that I can't blame anyone but myself if things go wrong. If you make a mistake during the rebuild, and it trashes the block, are you prepared to deal with that? Does rebuilding the engine yourself sound interesting? If not, might be a better choice to go with a replacement.
You could also split the case to get a better idea of what you're dealing with, then make a decision.
I am also a gearhead and normally I would take this engine apart and all that, but I am 16 and this is a dream jet ski I have wanted for many many years. The jet ski is draining more money than I can make, with all the problems I have found, plus buying tools. I don't really have the funds to mess up an engine rebuild or to buy all the tools needed at this point. Like you said, I don't think I can deal with myself trashing the block, partly because I don't have the funds to buy a new engine without core trade in.
With splitting the case, do I have to remove the top end of the engine? If it is as simple as just unbolting the bottom end of the crankcase, then I can do that, but I don't have all the tools to reassemble the top and bottom end.
Ok, well thanks for your help! I bought the new engine, which is supposed to come in around 9 weeks. Meanwhile, I had a question about reconnecting the jet pump to the ski. I already pulled the pump off the ski, and it had the silicon. My question is, where and what type of silicon do I need when I connect the pump to the ski?
