Easy way to remove decals
noviceskier
Since the decals were damaged and faded I just felt like it would be appropriate to remove the badly damaged ones preserving the ones in moderately good condition.
Tried the heat gun and razor removal, worked on the smaller bits but process was slow and not as efficient as I wanted it to be. Found a better alternative which removed the decals in minutes. Using my 16v matco drill and an eraser pad made quick work with them. Although not the correct tool to be used with the pad it does work and easily too.
Doesn't damage the gelcoat either if you were to not be as careful with a razor blade. Although depending on what drill you have it can overheat or not have enough power, but $10 for a pad which lasts to remove multiple skis. I think its something helpful for others having issues removing their decals.
I'll update the thread with pictures if needed. Just thought this would be helpful for others.
Now just to block the ski with higher grit sandpaper and patch some low and exposed bits of fiberglass with gelcoat and some polish finished with a coat of wax will make it look like new.
Also for restoring hoods too, found a rubbing compound made for restoring faded plastic too which made my plastic handlebar pads and hood have the black shine as if it wasn't sitting in the woods for years.
I like the 3M wheel, but I did find that they wear pretty quickly. It’s probably not a big deal on a ski, but I went through a couple on my Speedster before I got through all of the decals...
Here you go, one of the best hull retailers here on the forum did a write up.
Pictorial On how to buff your faded nasty hull
I like mothers, and we get a great price for them too, did a test spot on my HX hood and turned out shiny yellow again, although I sanded it back down since I'm going to do gelcoat repair on the hood. Thanks for the thread! I will buy their wax, although you shouldn't need swirl remover. Just a couple seconds on the wheel and wipe with a clean rag and your set.
Also cleaning your pad, I use a paint paddle, get it at a low rpm and just put the edge of the paddle on the pad and watch as it cleans itself, followed by compressed air and you are set.
I've switched over to 3m buffing supplies since that thread. Check my HX thread on my buff job.
buffing compound vs polish are different, pretty easy to get a good finish polishing but buffing is a lot more time consuming
only reason I switched to mothers is because we switched suppliers, no difference noticed personally. So I'm fine with both
FWIW, a local sign shop told me a lot of sprays remove glue, but PB Blaster works the best.
Holy Smoke this is a good thread! :) Truly then there is more than one way to "skin a jetski" !! I likes me some PB Blaster anyway I am gonna give it a shot or 3. Good Stuff !! :D :D
I've used my wheel on three different skis to remove all decals. It's probably about half way done.
For the cost of the wheel and the time and effort saved it's worth it to me
When removing decals a heat gun works effectively, then a little Goof Off product on a rag if there's any stickyness left behind.
Can I get a picture of the amazing "wheel"? I'm all about easier, quicker, and more effective. :)
