how long has this been going on? the crank seals rarely fail that badly. are you sure it isn't winter storage oil, or from just sitting over the winter. my skis kill mosquitos for miles around first start-up of the year. after that they are fine. another way to check injection pump is to block it off and pre-mix the gas. don't do this for long, unless you are gonna remove the pump and install a block-off plate.
