I have been having a problem not being able to keep the front rubber shaft bumpers from being destroyed after a few hours of use. The shaft slips forward against the PTO so there is little spline left for the shaft spline to match up to and starts wearing the PTO splines(softer metal). In my case, as soon as the bumper is chewed up, the shaft slides forward-- the shaft ceases to turn because the PTO shaft splines have been destroyed on the front side and there is no spline left, install a rubber bumper and it holds the shaft back enough into good spline territory on the PTO until again the rubber bumper is chewed up. This has been an ongoing problem.
I thought I'd solve the problem by installing 3 pennies(the thickness of 1 rubber bumper) inside the PTO where the rubber bumper would have been. It held up for a while but the forward thrust( I know, there should'nt be any there) smashed the pennies so much, the shaft slid forward again and again the engine spins and the shaft does not. There is some serious forward thrust on those pennies, no wonder the rubber bumper don't hold up. I'm replacing the PTO because I don't have any splines left for the shaft to work with but I still have the forward thrust problem on the bumpers.
Any Ideas here?????
Could it be an engine alignment problem???
Any Ideas here?????
