9 95xpyellow New Member May 29, 2024 #1 Hey just wondering what I should put on the splines of the pump end of the drive shaft. Grease or anti seize?
mkov608 Active Member May 31, 2024 #3 I use ExxonMobilith SHC100, and I use that in my jet pump bearings too because it matches the factory fill for the angle bearing (the grease that is packed into the new bearing when you receive it from the manufacturer.)
