Hey guys, long time looker first time user. But the problem i have i can't find the answer to.
I own a SeaDoo XP 2000 that has caused me nothing but grief in the short time that i have owned it.
I firstly broke the engine off it's mounts and the local dealer replaced all mounts, replaced both couplers and drive rubber aswell as re aligning the motor. And have only done around 4 hours on it.
Only today i replaced the jetpump housing that contained a new impeller and wear ring that was installed into the housing by the dealer, i simply just fitted the pump housing.
Well here is the problem, i went out after installing the housing and the Ski ran great (for about 15 mins) then the noise came back, so i stopped straight away. When i inspected the engine compartment i found that the engine coupler and drive shaft coupler were no longer aligned correctly and there was no cush drive rubber to be found, it had completly chewed out both couplers and has put a hole in the fuel tank.
I spoke to the dealer immediately and he said that it was my fault cause i did not align the pump housing correctly, which i found this hard to believe when it simply just slides into position and there was no forcing, and as it is a 2-piece drive shaft how did i create the problem at the front of the ski?
But i came to the conclusion that he did not align the motor correctly the first time he replaced the engine mounts ( 4 hours ago ). Therefore it has slowly chewed the drive rubber out and now coincidently has disengadged/smashed the drive couplers.
Would this be a correct assesment of what could of happened or was it my fault. It is just coincidental that it happened the same day i installed the pump housing ?????
Please HELP ME!
Cheers guys,
Mitch
Please HELP ME!
Cheers guys,
Mitch
