So had another failure on the boat. Put it in the water, started driving and there was a thump and then lost almost all propulsion.
Back to the dock, out of the water, checked the impeller, nothing caught in there. didnt run anything over.
Take it to the shop and they tell me the drive shaft stripped, and i need a new drive shaft, but it is discontinued. They also tell me the wear ring and impeller are worn and might as well change them at the same time. Last part I need is a "bolt" that connect the driveshaft to the impeller, and that bolt is $110.
Where can I find a driveshaft if it is discontinued?
What would cause this issue? Wear and tear? Or could the engine not being aligned properly cause this. The shop JUST installed a brand new engine in June.....
Thanks Guys.
Thanks Guys.
