SurfBeat
Way back in January 2009, a ember responded to a Thread posted by another Member who was stoked on only using the "special tool" to align the Drive Shaft from the Jet Pump to the PTO.
Although the question I have is relevant to that Post, because the Thread is officially closed, coupled with the fact that I have an additional question that was not covered in that Thread or others, I am starting this Thread.
To provide some relevant history regarding that Thread, the Member who responded to the Thread offered a different opinion regarding only using a "special tool," stating in relevant part that:
"You can use the tool if you want. When I put my engine back in I just made sure all the shims were put back where they were before. Put everything back together, put the drive shaft on, put motor mounts on but leave them kinda loose. Bump the starter and it will align itself, then torque mounts down and your done. Never had a problem with it."
In my case, while troubleshooting a frozen PTO, I first removed the Jet Pump, then moved on to remove the engine to replace a defective crankshaft.
I now have re-installed the engine which before attaching the Exhaust Pipe (EP) to both the Manifold and Muffler was easy to move from side to side, up and down.
My question is, because the engine is now very difficult to move since I attached the EP to the manifold and muffler, should I not have installed the Exhaust Pipe before installing the Jet Pump and sliding the Driveshaft through the Hull to align with the PTO?
If I did the correct procedure as set forth above, then, do I do the best I can to align the driveshaft between the Jet Pump and PTO, then bump it as suggested by the above Member?
I apologize for the long worded Thread, however, I did my best to set forth my question in as short a manner as possible.
