Drain Plug
This a lame question but my last jet boat had a plug at the back of the boat and I let the H2O drain on the way home. I am assuming on my 96 speedster it is the threaded hole at the back between the jets.
That threaded hole could either be the drain plug or where you attach the water hose to rinse out your engine, boat ect..
if its in the direct middle of the hull on the bottom its the drain hole. If its on the top left of the Jet its the hose hook-up
