Ok, so many of you know this already. But if you need some convincing, this is hopefully it. Don't buy a cheap aftermarket starter. I was told the same thing on these forums, but didn't listen since there was no "proof". Hopefully this is "proof" for someone else:
I was debugging a starter issue where the motor would struggle to turn over with the plugs in. It turned out the cause was because of long jumper cables to an external battery in my test setup. But not knowing this at the time, and being very confused of what is wrong, I decided to get a cheap $70 aftermarket starter on ebay. I believe the $100-$120 starters from other places online are identical Chinese junk.
I have had it in for about one month working fine. Two salt days, 2 freshwater days. Very little water in the bilge, defiantly didn't get on the starter. The starter is rusting in one month! I ended up shorting out the positive to ground (due to over tightening the positive wire because of what I believe to be a very bad design in the seadoo starter, not just the chinese version). So I took it apart. The screws that hold the motor together are already rusting. I originally chipped a few small flecks of paint off the outside cover installing it and now the outside metal is rusting. I took the thing apart and even the inside case is rusting from the inside. The quality of the metal is chinese garbage that will rust amazing quickly.
Now I don't completly regret the decision because when the new starter did the same as the old one, it was another piece of information. I consider it my service charge at the dealer to tell me what was wrong.
If anyone is considering replacing their starter with the cheap ones, I couldn't see the metal lasting for more than 1-2 years. If your getting it for a test, than maybe its worth it. If you are getting as a replacement, then do not get it. It would be interesting to know people's experience with the "Aqua High Torque" motors. Perhaps their quality is a little better.
I ended up replacing the two brushes in the original motor and rebuilt it. Works perfectly and is in great condition. The metal case is a completly different material and is MUCH better quality. Paint was already chipped off this one, and their is no signs of any rusting.
Hope this helps convince someone...
I'll also throw in some helpful hints about the bad design of this Seadoo starter. When replacing the positive brush there is a very small piece of plastic that acts as the nut on the inside of the case. When you start tightening a nut on the outside terminal bolt, you put a lot of pressure on this little plastic nut on the inside. I ended up breaking this when torqueing the positive terminal onto the starter bolt. There is only a few mm of clearance from what seperates the positive lead to the grounded case. This imo, is a terrible design. When you break the little plastic nut on the inside, you start twisting the whole positive bolt. Then the positive bolt or brush touches the case. The manual tells you to use RED locktite on this tiny bolt. I think this is because the design is not good.
So to install my positive lead on my new motor I was very careful to not apply to much torque on the first nut that holds the positive bolt in place. I then took the positive terminal and tightened it between two additional bolts. I torqued the hell out of those two against each other, making sure not to apply any pressure on the original nut or bolt. The + bolt on the starter isn't quite long enough for all three nuts. The last bolt fits only 1/2 to 3/4 but it looks like it makes a good connection. I also used lock washers and locktite since I have so many problems with these starters.
