Guest_User
Does anyone know if the tachometers clear lens (98 Challenger 1800) can be removed or the tach taken apart to repaint the needles?
Yes and no...
NO: they were not meant to come apart.
BUT
Yes: you can cut off the metal lip... and remove the lens. Then... just put it back on with black RTV.
It's not perfect... but it's better than throwing a gauge away.
I read somewhere on SDF that you could send them back to the manufacturer and they can refurb them, not sure how true that was. Flip thru the phone book and see if you can find a speedometer repair/restoration/calibration shop near by. Yes, I said phone book, it's a dying art and most of those cats prolly don't know what the interwebs are. Perhaps they could take it apart and put it back together properly
Faria instruments makes them for all the newer sea doo products. They may also make the older models. If so you can ship them in and they rebuild them and make em look new and send them back with a warranty for like 40-50 each.
They use to have all the rebuild info on their site. Im not sure if it is still there. Try looking around or calling them.
http://www.faria-instruments.com/
Heere ya go:
http://faria-instruments.com/forms/?form=new
Had my gauges out and the fuel / oil gauge dropped and broke the glass lens.
So.. I replaced the Speedo gauge with a GPS type (AndyTech)
I then split the rings off both Speedo and Fuel gauges and removed the soft white center ring and the glass lens.
I replaced the white ring inside, painted the needles and put the speedo lens on the Fuel gauge.
Then using a zip tie and J P Weld, I filled the cut off grove(like bondo) let it dry a couple days
I them sanded it and painted it (sm. brush) flat black
Moved the cut to the bottom of the guage and you have to look very hard to see its been apart.
