Its been a bit since I made the swap, but there are some differences. The main ones I know of are the cooling system. The white motors ciculate water a bit better & use different exhaust manifolds. The yellows have a different block. they lack the threaded boss's for the PTO flywheel cover, & have different mounting for the mag housing. If you have a yellow motor, you can't use the white mag housing. The larger yellow housing has all the iginition electronics housed inside, the white has them in the E-box. Otherwise the pistons & cranks are the same & they will swap, you just need to keep the exhaust for each style. The white stator & flyweel will bolt onto the yellow engine, I have made that swap before. I think I might even have some pictures......
